<PROGRAMMATEUR_ARROSAGE>
<ACTION></ACTION>
<PROGRAMME>Auto</PROGRAMME>
<STATUT_CYCLE>ARROSAGE PREVU A 21:37|-Z1-0 mn|</STATUT_CYCLE>
<PLUIE_CUMUL_JOUR>147.5</PLUIE_CUMUL_JOUR>
<PLUIE_CUMUL_JOUR_1>117.5</PLUIE_CUMUL_JOUR_1>
<PLUIE_CUMUL_MOIS_1>29</PLUIE_CUMUL_MOIS_1>
<PLUIE_JOUR_0>30</PLUIE_JOUR_0>
<PLUIE_MOIS_0>118.5</PLUIE_MOIS_0>
<PLUIE_CUMUL>89.5 mm sur 3 jours</PLUIE_CUMUL>
<TEMP_MAX>16.7</TEMP_MAX>
<TEMP_MIN>13.1</TEMP_MIN>
<EVAP_JOUR_0>2.45</EVAP_JOUR_0>
<EVAP_MOIS_0>15.37</EVAP_MOIS_0>
<EVAP_CUMUL>11.85 mm sur 3 jours</EVAP_CUMUL>
<ARROSAGE_JOUR_EST>0</ARROSAGE_JOUR_EST>
<ARROSAGE_JOUR_0>0</ARROSAGE_JOUR_0>
<ARROSAGE_MOIS_0>0</ARROSAGE_MOIS_0>
<ARROSAGE_CUMUL>0 mm sur 3 jours</ARROSAGE_CUMUL>
<DERNIERE_PLUIE>16-06 00:04</DERNIERE_PLUIE>
<JOUR_SANS_PLUIE>0</JOUR_SANS_PLUIE>
<DERNIER_ARROSAGE>13-06 00:00</DERNIER_ARROSAGE>
<JOUR_SANS_ARROSAGE>3</JOUR_SANS_ARROSAGE>
<HORAIRE_CHECK>16-06 00:02</HORAIRE_CHECK>
<PROCHAIN_ARROSAGE>17-06 21:37</PROCHAIN_ARROSAGE>
<VAL_MODE>1</VAL_MODE>
<STR_MODE>AUTO</STR_MODE>
<FREQUENCE_ARROSAGE>3</FREQUENCE_ARROSAGE>
<ARROSAGE_COEF>0</ARROSAGE_COEF>
<ARROSAGE_REPORTE>OUI</ARROSAGE_REPORTE>
<ARROSAGE_AVANCE>NON</ARROSAGE_AVANCE>
<ARROSAGE_j0>PAS_ENCORE</ARROSAGE_j0>
<DEBUT_DE_CYCLE>Wed, 17 Jun 2020 21:37:00 +0200</DEBUT_DE_CYCLE>
<ELECTROVANNE_1>Arrosage Extérieur - Debut a 21:37 - fin a 21:37 - pendant 0 mn</ELECTROVANNE_1>
<mm_evap_jn_cum>11.85</mm_evap_jn_cum>
<mm_evap_cum_j0>15.37</mm_evap_cum_j0>
<mm_evap_j0>2.45</mm_evap_j0>
<mm_evap_j1>4.73</mm_evap_j1>
<mm_evap_j2>4.67</mm_evap_j2>
<mm_evap_j3>3.52</mm_evap_j3>
<mm_evap_j4>0</mm_evap_j4>
<mm_evap_j5>0</mm_evap_j5>
<mm_evap_m0>15.37</mm_evap_m0>
<mm_evap_cum_j1>12.92</mm_evap_cum_j1>
<mm_evap_cum_m1>0</mm_evap_cum_m1>
<mm_pluie_jn_cum>89.5</mm_pluie_jn_cum>
<mm_pluie_cum_j0>147.5</mm_pluie_cum_j0>
<mm_pluie_j0>30</mm_pluie_j0>
<mm_pluie_j1>30</mm_pluie_j1>
<mm_pluie_j2>29.5</mm_pluie_j2>
<mm_pluie_j3>29</mm_pluie_j3>
<mm_pluie_j4>0</mm_pluie_j4>
<mm_pluie_j5>0</mm_pluie_j5>
<mm_pluie_m0>118.5</mm_pluie_m0>
<mm_pluie_cum_j1>117.5</mm_pluie_cum_j1>
<mm_pluie_cum_m1>29</mm_pluie_cum_m1>
<mm_arros_jn_cum>0</mm_arros_jn_cum>
<mm_arros_cum_j0>0</mm_arros_cum_j0>
<mm_arros_j0>0</mm_arros_j0>
<mm_arros_j1>0</mm_arros_j1>
<mm_arros_j2>0</mm_arros_j2>
<mm_arros_j3>0</mm_arros_j3>
<mm_arros_j4>0</mm_arros_j4>
<mm_arros_j5>0</mm_arros_j5>
<mm_arros_m0>0</mm_arros_m0>
<mm_arros_cum_j1>0</mm_arros_cum_j1>
<mm_arros_cum_m1>0</mm_arros_cum_m1>
<FIN_DE_CYCLE>Wed, 17 Jun 2020 21:42:00 +0200</FIN_DE_CYCLE>
<LAST_RUN_MAJ_VAL>Tue, 16 Jun 2020 08:24:12 +0200</LAST_RUN_MAJ_VAL>
<LAST_RUN_MAJ_SONDE_DUREE>Tue, 16 Jun 2020 08:24:12 +0200</LAST_RUN_MAJ_SONDE_DUREE>
<LAST_RUN_MAJ_TIME_ARROS>Tue, 16 Jun 2020 00:02:59 +0200</LAST_RUN_MAJ_TIME_ARROS>
<LAST_RUN_MAJ_DAY_ARROS>Tue, 16 Jun 2020 00:01:58 +0200</LAST_RUN_MAJ_DAY_ARROS>
<LAST_RUN_MAJ_MODE_ARROS>Sat, 13 Jun 2020 14:13:06 +0200</LAST_RUN_MAJ_MODE_ARROS>
<LAST_RUN_MAJ_DATA_ARROS>Thu, 01 Jan 1970 01:00:00 +0100</LAST_RUN_MAJ_DATA_ARROS>
<COMMENT>
var_ext : _ARR1948665
ETAT VARIABLE INITIAL
Version : 5.01
Action : read
maj_init_data
maj_mode_arros
maj_day_arros
maj_time_arros
maj_sonde_duree
action retraitee read
action boucle read
ETAT VARIABLE FINAL
Action : read
maj_init_data
maj_mode_arros
maj_day_arros
maj_time_arros
maj_sonde_duree
api_periph_appelant 1987711
tb_api['api_parent'] 1987710
</COMMENT>
</PROGRAMMATEUR_ARROSAGE>
http://localhost/script/?exec=prg_arros_v5.php&action=read&api_pluvio=1948665&var_maj_nom=last_arrosage&var_maj_val=0&eedomus_controller_module_id=1987712
jmvong a écrit:Bjr
version du 21/06/2020 - V5.05
Il est maintenant possible de saisir une adresse à l'étranger pour calculer le coucher du soleil lors de l'installation
Cdlt
JM Vong
epsonus a écrit:Bonjour,
à l'installation du plugin, cela demande le temps pour arroser 10mm de pluie. Question peut-être stupide mais sur quelle base se fait cette mesure?![]()
si je mets un plat "plat" ou un saladier, ou une tasse je n'aurais pas les mêmes mesures. Vu que cela doit impacter la durée d'arrosage j'imagine qu'il ne faut pas mettre n'importe quoi...
l'heure de demarrage de l'arrosage est fonction du programme
soit l'heure du coucher de soleil calculée à partir de la longitude/lattitude saisies si [VAR3]="soleil"
soit une heure fixe stockée dans [VAR3]
bouliboule a écrit:Serait-il possible de régler l’heure d’arrosage ? En effet la meilleure heure n’est pas le soir mais très tôt pour les raisons suivantes : moins d’évaporation, humidité qui reste moins présente en surface donc moins de champignons ou fil rouge etc.
Merci pour ce plugin qui a l’air très prometteur en tout cas.
Utilisateurs parcourant ce forum : Google [Bot] et 25 invité(s)
