SONOS TTS gets truncated
Messagepar Horia » 04 Sep 2019 09:57
Hi All,
I have many TTS messages but this one http://localhost:5005[VAR1]/say/Vous avez 30 seconds pour désactiver la surveillance des intrusions!/fr-fr/60 gets truncated, ie stops after "surveillance" or "des" when played through the box, trigger by a rule or manually through the UI test function.
On Google translate plays very well.
I raised a ticket but maybe you have suggestions.
Thanks for advise, Horia
Maison avec eedomus+, 200 dispositifs(60 en zwave/+, 10 en RFXcom, 5 cameras, les restes virtuel), automatisation éclairage, sécurité maison, environnement, access, chauffage, notifications, agenda.
Horia
Re: SONOS TTS gets truncated
Messagepar merguez07 » 04 Sep 2019 10:13
Hi Horia,
I did the test at home and everything worked out well. The sentence has not been truncated. I have no idea why it does not work at your home.
Messagepar Horia » 04 Sep 2019 10:20
Thanks.
Something is wrong in my box. I started getting notifications when new messages play saying XML error: Script introuvable [script.php], I don't see the script in the UI of the box, but the messages play :-)...
Horia
Horia
Messagepar Horia » 04 Sep 2019 10:33
I think by mistake I clicked once in the past on the edit script. I updated now the baseline URL with http://localhost:5005[VAR1]/state and the message played well without any error notification.
Thanks again, Horia
Horia
Messagepar Horia » 04 Sep 2019 13:05
Very strange, few more manual UI triggered tests, again the message truncates.
Horia
Horia
Messagepar Horia » 04 Sep 2019 13:15
FYI: I removed the room from the VAR1 variable and now it plays completely and the start delay is smaller. Hopefully this will be persistent.
Horia
Retour vers Objets connectés
Utilisateurs parcourant ce forum : Google [Bot] et 12 invité(s)
