Apple Homekit not working
eedomus iOS app available on the appStore
Messagepar davsdom » 17 Déc 2018 22:15
HI,
I'm not able to work with eedomus and Homekt by apple. I can add all zwave devices, and they are shown as "no response". It was working just for one day, the first day I installed it....
I have other systems homekit compatible (Tado) and they work without problems.
any suggestions???
thanks in advace.
David
davsdom
Re: Apple Homekit not working
Messagepar davsdom » 09 Jan 2019 00:47
no answer? planning to buy the suscription but if APple homekit it's not working I'm not sure to do it...
please help.
Thanks.
davsdom
Messagepar AliOrdo » 11 Jan 2019 21:32
Hi David,
I'm facing the same issue as you.
Did you manage to fix it?
if so, Would you be so kind to share how you did it?
Many thanks in advance,
Diego
AliOrdo
Messagepar davsdom » 11 Jan 2019 21:58
Nope. Not solved. Apple HomeKit works perfect with Tado (climate control) and Sonos, but eedomus is not working any more.
Thinking about changing the controller to another just because I thought in eedomus for Apple HomeKit and special interface.
Now using Alexa but Alexa is so far away (roller as lights)
Eedomus inferface for iOS (I have iPads in each room) is not working fine either (delays, icons so small, cannot fix the design of each room). ...
What a pitty with this controller.
Last time I checked eedomus website I think apple HomeKit compatible has been deleted, but not sure.
Support about this matter is nule.
Should I buy the subscription for eedomus??? So hard thinking about it
Please any help will be so appreciated.
Sent from my iPhone using Tapatalk
davsdom
Messagepar davsdom » 17 Jan 2019 00:25
Hi. I’ve added an iPad as home center controller for HomeKit and I’ve deleted all scenes and programs in eedomus , and apple HomeKit is working from several days ago ...
davsdom
Messagepar AliOrdo » 06 Fév 2019 13:22
Hey David,
Many thanks for coming back to me.
Unfortunately, I'm in a similar situation, I raised a ticket a couple of days ago to eedomus tech support but no answer yet.
I will give it a try to your solution, until now everything that I have tested to connect eedomus with Homekit is not working.
I will keep you posted.
Thanks,
Diego
AliOrdo
Retour vers iOS app
