[20:36:39.953] Setting node #21=100:
[20:36:39.954] ## DEBUG: This is not an always listening node, queuing the action request.
[20:36:39.954] ## DEBUG: Writing queue command [/var/inbox/zwave_queue/21/non_listening_set_2095043.req]
[20:36:39.955] Creating request [/mnt/flash/puch/outbox/supervisor_2095043.req]
[20:36:47.136] ## DEBUG: Skipping [switch_multilevel_get] polling for node #10 channel #1 (error_count=41 last_polling_delay=2641).
[20:36:47.368] ## DEBUG: Skipping [switch_multilevel_get] polling for node #10 channel #2 (error_count=41 last_polling_delay=2614).
[20:36:47.598] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #10 channel #11 (error_count=41 last_polling_delay=2587).
[20:36:47.834] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #10 channel #12 (error_count=41 last_polling_delay=2560).
[20:36:48.073] ## DEBUG: Skipping [read_meter_kwh] polling for node #10 channel #21 (error_count=41 last_polling_delay=2534).
[20:36:48.305] ## DEBUG: Skipping [read_meter_kwh] polling for node #10 channel #22 (error_count=41 last_polling_delay=2519).
[20:36:48.538] ## DEBUG: Skipping [switch_multilevel_get] polling for node #11 channel #1 (error_count=42 last_polling_delay=2503).
[20:36:48.771] ## DEBUG: Skipping [switch_multilevel_get] polling for node #11 channel #2 (error_count=42 last_polling_delay=2475).
[20:36:49.014] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #11 channel #11 (error_count=42 last_polling_delay=2448).
[20:36:49.247] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #11 channel #12 (error_count=42 last_polling_delay=2421).
[20:36:49.480] ## DEBUG: Skipping [read_meter_kwh] polling for node #11 channel #21 (error_count=42 last_polling_delay=2393).
[20:36:49.713] ## DEBUG: Skipping [read_meter_kwh] polling for node #11 channel #22 (error_count=42 last_polling_delay=2377).
[20:36:49.947] ## DEBUG: Skipping [switch_multilevel_get] polling for node #12 channel #1 (error_count=55 last_polling_delay=2361).
[20:36:50.190] ## DEBUG: Skipping [switch_multilevel_get] polling for node #12 channel #2 (error_count=55 last_polling_delay=2335).
[20:36:50.426] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #12 channel #11 (error_count=55 last_polling_delay=2308).
[20:36:50.661] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #12 channel #12 (error_count=55 last_polling_delay=2281).
[20:36:50.898] ## DEBUG: Skipping [read_meter_kwh] polling for node #12 channel #21 (error_count=55 last_polling_delay=2254).
[20:36:51.132] ## DEBUG: Skipping [read_meter_kwh] polling for node #12 channel #22 (error_count=55 last_polling_delay=2239).
[20:36:51.370] ## DEBUG: Skipping [switch_multilevel_get] polling for node #13 channel #1 (error_count=45 last_polling_delay=2223).
[20:36:51.605] ## DEBUG: Skipping [switch_multilevel_get] polling for node #13 channel #2 (error_count=45 last_polling_delay=2196).
[20:36:51.839] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #13 channel #11 (error_count=45 last_polling_delay=2132).
[20:36:52.073] ## DEBUG: Skipping [read_meter_channel_shifted] polling for node #13 channel #12 (error_count=45 last_polling_delay=2106).
[20:36:52.309] ## DEBUG: Skipping [read_meter_kwh] polling for node #13 channel #21 (error_count=45 last_polling_delay=2079).
[20:36:52.551] ## DEBUG: Skipping [read_meter_kwh] polling for node #13 channel #22 (error_count=45 last_polling_delay=2063).
[20:36:52.786] ## DEBUG: Skipping [switch_multilevel_get] polling for node #14 (disabled).
[20:36:53.030] ## DEBUG: Skipping [battery_get] polling for node #14 since 4783/21600sec.
[20:36:53.265] ## DEBUG: Skipping [read_temperature] polling for node #14 channel #2 since 1015/1800sec.
[20:36:53.500] ## DEBUG: Skipping [read_temperature] polling for node #14 channel #3 (disabled).
[20:36:53.742] ## DEBUG: Skipping [basic_get] polling for node #15 (disabled).
[20:36:53.978] ## DEBUG: Skipping [battery_get] polling for node #15 since 4739/21600sec.
[20:36:54.212] ## DEBUG: Skipping [read_temperature] polling for node #15 channel #2 since 193/1800sec.
[20:36:54.446] ## DEBUG: Skipping [read_temperature] polling for node #15 channel #3 (disabled).
[20:36:54.679] ## DEBUG: Skipping [switch_multilevel_get] polling for node #16 (disabled).
[20:36:54.922] ## DEBUG: Skipping [battery_get] polling for node #16 since 4738/21600sec.
[20:36:55.156] ## DEBUG: Skipping [read_temperature] polling for node #16 channel #2 since 179/1800sec.
[20:36:55.390] ## DEBUG: Skipping [read_temperature] polling for node #16 channel #3 (disabled).
[20:36:55.651] ## DEBUG: Skipping [switch_multilevel_get] polling for node #17 (disabled).
[20:36:55.893] ## DEBUG: Skipping [battery_get] polling for node #17 since 4737/21600sec.
[20:36:56.147] ## DEBUG: Skipping [read_temperature] polling for node #17 channel #2 since 163/1800sec.
[20:36:56.401] ## DEBUG: Skipping [read_temperature] polling for node #17 channel #3 (disabled).
[20:36:56.642] ## DEBUG: Skipping [switch_multilevel_get] polling for node #18 (disabled).
[20:36:56.875] ## DEBUG: Skipping [battery_get] polling for node #18 since 4694/21600sec.
[20:36:57.117] ## DEBUG: Skipping [read_temperature] polling for node #18 channel #2 since 148/1800sec.
[20:36:57.350] ## DEBUG: Skipping [read_temperature] polling for node #18 channel #3 (disabled).
[20:36:57.587] ## DEBUG: Skipping [read_meter] polling for node #19 (disabled).
[20:36:57.820] ## DEBUG: Skipping [read_meter] polling for node #21 (error_count=36 last_polling_delay=132).
[20:36:58.054] ## DEBUG: Skipping [switch_binary_get] polling for node #22 (disabled).
[20:36:58.298] ## DEBUG: Skipping [battery_get] polling for node #22 since 4693/21600sec.
[20:36:58.532] ## DEBUG: Skipping [read_temperature] polling for node #22 channel #2 since 118/1800sec.
[20:36:58.765] ## DEBUG: Skipping [read_temperature] polling for node #22 channel #3 (disabled).
[20:36:59.001] ## DEBUG: Skipping [switch_multilevel_get] polling for node #23 (disabled).
[20:36:59.233] ## DEBUG: Skipping [battery_get] polling for node #23 since 4634/21600sec.
[20:36:59.473] ## DEBUG: Skipping [read_temperature] polling for node #23 channel #2 since 100/1800sec.
[20:36:59.710] ## DEBUG: Skipping [read_temperature] polling for node #23 channel #3 (disabled).
[20:36:59.716] ## INFO: '/etc/eedomus/zwave_polling' written.Setting node #21=100Setting node #19=0
ARTNOW a écrit:Salut Befree , c'est du boulot de repartir à zéro , mais pour une installation fiable , je crois que tu n'as pas le choix .
Le mieux c'est de couper tout tes périphériques , les remettre à zéro en les réinitialisant mode usine, commencer par les périphériques secteur , puis à piles .
Je pense que toutes autres solutions seraient du bricolage , et quand un jours tu auras un ou des bugs , tu ne sauras pas d'où cela viens ....![]()
Bon courage
misterden a écrit:Voila 1 semaine que j'ai ouvert un ticket pour une eedomus complétement HS , impossible à restaurer .... aucune réponse.
Fab_Rice a écrit:En voilà de la "good news"; j'espère que j'aurais la même "chance" avec mon ticket sur l'authentification Tado° (gestion complète de mon chauffage) qui est en rade depuis le 20/08 !![]()
Vous me direz, heureusement que c'est encore la belle saison
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 82 invité(s)
