SONOS TTS gets truncated
Messagepar Horia » 04 Sep 2019 09:57
Hi All,
I have many TTS messages but this one http://localhost:5005[VAR1]/say/Vous avez 30 seconds pour désactiver la surveillance des intrusions!/fr-fr/60 gets truncated, ie stops after "surveillance" or "des" when played through the box, trigger by a rule or manually through the UI test function.
On Google translate plays very well.
I raised a ticket but maybe you have suggestions.
Thanks for advise, Horia
Horia
Re: SONOS TTS gets truncated
Messagepar merguez07 » 04 Sep 2019 10:13
Hi Horia,
I did the test at home and everything worked out well. The sentence has not been truncated. I have no idea why it does not work at your home.
Messagepar Horia » 04 Sep 2019 10:20
Thanks.
Something is wrong in my box. I started getting notifications when new messages play saying XML error: Script introuvable [script.php], I don't see the script in the UI of the box, but the messages play :-)...
Horia
Horia
Messagepar Horia » 04 Sep 2019 10:33
I think by mistake I clicked once in the past on the edit script. I updated now the baseline URL with http://localhost:5005[VAR1]/state and the message played well without any error notification.
Thanks again, Horia
Horia
Messagepar Horia » 04 Sep 2019 13:05
Very strange, few more manual UI triggered tests, again the message truncates.
Horia
Horia
Messagepar Horia » 04 Sep 2019 13:15
FYI: I removed the room from the VAR1 variable and now it plays completely and the start delay is smaller. Hopefully this will be persistent.
Horia
Retour vers Objets connectés
