Plug in Ampli Yamaha Series RX-V
Re: Plug in Ampli Yamaha Series RX-V
Messagepar merguez07 » 16 Nov 2018 21:38
Salut Frasab
essaye de faire ça :
Remplace le code php du plugin par celui ci
// Permet de recuperer les variables de l'ampli Yamaha.
$IP_Ampli = Getarg('IPAmpli');
$url="http://" .$IP_Ampli ."/YamahaRemoteControl/ctrl";
$get='<YAMAHA_AV cmd="GET"><Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone></YAMAHA_AV>';
$content = httpQuery($url,'POST',$post = $get, $oauth_token = NULL, $headers = NULL, $use_cookies = false, $ignore_errors = false);
$Power=xpath($content, '/YAMAHA_AV/Main_Zone/Basic_Status/Power_Control/Power') ;
$Volume=xpath($content,'(/YAMAHA_AV/Main_Zone/Basic_Status/Volume/Lvl/Val)*(-0.1)');
$Source=xpath($content,'/YAMAHA_AV/Main_Zone/Basic_Status/Input/Input_Sel');
$Output1 =xpath($content, '/YAMAHA_AV/Main_Zone/Basic_Status/Sound_Video/HDMI/Output/OUT_1');
$Output2 =xpath($content, '/YAMAHA_AV/Main_Zone/Basic_Status/Sound_Video/HDMI/Output/OUT_2');
if ($Output1=='On'){
    $Output=' OUT_1';
if ($Output2=='On'){
    $Output=' OUT_2';
$get='<YAMAHA_AV cmd="GET"><Spotify><Play_Info>GetParam</Play_Info></Spotify></YAMAHA_AV>';
$Artiste=xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Meta_Info/Artist') ;
$Album=xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Meta_Info/Album') ;
$Piste=xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Meta_Info/Track') ;
$Etat =xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Playback_Info') ;
if (strpos ($Artiste,"NO_VALUE")===false) {
    saveVariable('ARTISTE', $Artiste);
    saveVariable('ALBUM', $Album);
    saveVariable('PISTE', $Piste);
} else{
    $Artiste=loadVariable('ARTISTE');
    $Album=loadVariable('ALBUM');
    $Piste=loadVariable('PISTE');
 // Generation du XML
sdk_header('text/xml');
    $xml = '<?xml version="1.0" encoding="UTF-8"?>';
    $xml .= '<Ampli_Yamaha>';
    $xml .= '<status>ok</status>';
    $xml .= '<power>' .  $Power .   '</power>';
    $xml .= '<volume>' . $Volume .  '</volume>';
    $xml .= '<source>' . $Source  . '</source>';
    $xml .= '<artiste>' .$Artiste . '</artiste>';
    $xml .= '<album>' .  $Album .   '</album>';
    $xml .= '<piste>' .  $Piste .   '</piste>';
    $xml .= '<etat>' .   $Etat .    '</etat>';
    $xml .= '<output>' .  $Output .    '</output>';
    $xml .= '</Ampli_Yamaha>';
echo $xml;
et dans l'actionneur Yamaha source tu modifies le xpath
/Ampli_Yamaha/source
par
concat(/Ampli_Yamaha/source,/Ampli_Yamaha/output)
Tiens moi au jus, si ça marche pas on fera d'autres manip
Messagepar frasab » 17 Nov 2018 11:52
Alors ça marche, mais :
- il est possible que les 2 sorties soient actives
- J'ai ajouté un actionneur HTTP pour pouvoir récupérer l'état (et les commander) pour baisser mon écran quand la bonne sortie est active
Merci beaucoup
frasab
Messagepar jeremy51 » 13 Mars 2019 17:52
Bonjour a tous,
je possède un ampli Yamaha HTR-4068 sur lequel j'ai une chromecast.
j'ai installé via le plug in du store eedomus mais a mon avis il faut que je fasse quelques modifs, par exemple je ne peux pas l'allumer mais par contre je peux l'éteindre.
Selon vous de quel côté dois je regarder ??
merci de votre aide
jeremy51
Messagepar jpdoj » 19 Déc 2019 20:41
Besoin de votre aide.
J'ai bien installé le plug Yamaha sur mon lecteur réseau et pré ampli YAMAHA WXC- 50 ... merci au concepteur.
Il est bien détecté par l'eedomus.
Mon soucis :
Je peux allumer et arrêter via l"eedomus
Mais L'ampli se rallume seul sans cesse.
une idée ?
Apres la Zibase ... (snif) suis tout nouveau sur eedomus j'ai donc besoin de conseils
Merci par avance.
Me voila sur L'eedomus après de longues années sur la défunte Zibase.
Tout à refaire et presque tout à apprendre !
jpdoj
Messagepar chris-s » 31 Déc 2019 10:58
Bonjour tout le monde !
Après plusieurs mois d'utilisation du plugin, j'ai trouvé son utilité avec la Google Home qui me permet d'allumer l'ampli sur une NET RADIO facilement.
Par contre, je viens de m'abonner à Spotify et je coince un peu.
J'arrive bien à commander précédent/suivant/pause/lecture à la voix avec des scènes eedomus via Google Home en vocal mais là où je sèche c'est pour lancer directement une musique particulière sur Spotify.
Exemple :
Je dis "OK Google met de la musique sur spotify" => musique sur Google home
Mais pour passer sur l'ampli je suis obligé d'utiliser l'appli spotify pour rediriger le son vers l'ampli.
Y a t-il un moyen de le faire par commande vocale ?
eedomus+ depuis le 15/01/2016
chris-s
Messagepar dav001 » 28 Jan 2020 23:13
Je suis tout nouveau dans la communauté et sollicite une âme charitable qui pourrait peut-être m'aiguiller.
serait-il possible d'ajouter dans les sources du plug in ampli Yamaha l'entrée Bluetooth qui est disponible sur le modèle RX-A3060 ?
Le plug in fonctionne super bien sur ce modèle ;)
Un grand merci d'avance.
dav001
Messagepar yannsud » 23 Août 2020 13:29
je suis nouveau sur le forum :P , pas encore basculé sur eedomus, mais je l’espère, je suis actuellement sur tydom1.0.
ma question est est ce quelqu'un a déjà testé ce plug in sur un yamaha RXA-1080? car évidemment j'en possede un ai ;)
merci de vos reponses
yannsud
yannsud
Messagepar onpjf » 09 Jan 2021 22:52
Installé ce jour avec un RX-V683. Cela fonctionne bien, j'ai quelque latences dans les commandes mais cela doit venir de mon réseau. Je continue mes investigations.
Encore merci pour ce plugin.
onpjf
Messagepar yannsud » 05 Fév 2021 19:43
je viens d'essayer mon yamaha RXA 1080, c'est ok c'est reconnu, donc on peut valider les series RXA :D
yannsud
Messagepar rbo » 01 Août 2021 12:28
Bonjour, Merci pour ce pluggin!
Je suis complètement novice et incompétent en programmation, mais je souhaiterais faire une règle pour déclencher un son via la fonctionnalité SERVER de mon ampli Yamaha (RX V773). Pour cela j'ai mis mes fichiers sonore sur ma freebox (en Disque dur) et mon ampli est bien connecté à mon réseau.
Ma question est la suivante : je pense qu'il faut que je modifie la valeur POST du SERVER de :
<YAMAHA_AV cmd="PUT"><Main_Zone><Input><Input_Sel>SERVER</Input_Sel></Input></Main_Zone></YAMAHA_AV>
vers
<YAMAHA_AV cmd="PUT"><Main_Zone><Input><Input_Sel>SERVERle bon chemin sur explorateur de fichier freebox du style /Freebox Server/ Fichiers/NO NAME/Mon dossier</Input_Sel></Input></Main_Zone></YAMAHA_AV>
Est ce correct?
Merci 1000 fois pour votre aide!
rbo
Messagepar merguez07 » 02 Août 2021 16:47
Salut rbo,
en fait si tu veux faire jouer une musique précise sur ton ampli yamaha il ne faut pas utiliser le plugin objet de ce topic.
Il te faut installer le plugin UPnP actionneur et lui mettre l'IP de ton ampli yamaha
configuration/ajouter ou supprimer un périphérique/ajouter un autre type de périphérique/UPnP actionneur
dans la valeur charger piste de ce plugin il te faudra mettre le chemin vers ton fichier mp3.
Un petit coup de "charger piste", puis "play" et le tour est joué
Messagepar misteurz » 18 Jan 2024 12:48
J'utiliser ce plugin depuis des années avec ma eedomus.
tout marche très bien, y compris l'intégration à Google Home.
Je viens de passer sur iPhone, et je n'arrive pas à l'intégrer sur Apple Homekit. Auriez-vous des idées?
J'aimerais simplement faire allumer et éteindre mon ampli (R-N500).
Merci d'avance,
Julien
misteurz
Retour vers Outils tiers
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 93 invité(s)
