Exclusion massive
Exclusion massive
Messagepar Ferritales » 13 Oct 2016 15:32
Bonjour a tous,
y a t'il une manière d'exclure tout les modules d'un coup, sans s'amuser un par un?
F.
Ferritales
Re: Exclusion massive
Messagepar Yesnie » 14 Oct 2016 13:14
En faisant un Reset de la puce Zwave, tu perd tous les modules...
Yesnie
Messagepar Horia » 14 Oct 2016 13:51
Only if you don't preserve the Node ID for the Z-Wave Controller in the box.
Otherwise, the devices will still be able to communicate with the box based on their current routing even that the box will show a quite empty routing table (practically you will see just the routes in use).
Meanwhile, even if you don't preserve the Node ID, you still have to manually exclude each of those devices, to be able to re-include them later and you loose all rules, device objects.
If your goal is to stabilise a Z-wave network, better you reset the Z-wave controller, preserve the node ID and re-include one by one and slowly each of your devices...None of the rules, device objects are affected this way.
I applied this in my home and I got a stable network for few months now.
Horia
Messagepar Ferritales » 15 Oct 2016 21:13
Thanks Guys.
Ferritales
Utilisateurs parcourant ce forum : Google [Bot], jasperwilde11 et 23 invité(s)
