Fibaro Motion Sensor (FGMS-001) Battery FYI for comments
Everything about Z-Wave radio devices with eedomus
Messagepar Horia » 12 Nov 2022 11:32
Hi All,
I have many Fibaro sensors installed. Since 20219, I timed based (5min interval) or disabled when not required their temperature and light updates, and saw battery improvements.
For some of them, where there is constant movement, a battery from January 2020, arrived to be 3% in August 2022 and I decided to keep it see what happens. Even now, it shows 3%, almost 3 months past. In other cases where there is less movement last battery change was almost 4 years away...
The only disturbance is to see in the web and app UIs the notifications for the low battery levels...They start from below 10%, and is annoying to close them. In my view, eedomus should enable customisable notification levels, and as last resort we have the notification for when the sensor has not communicated over a configured time.
All this as FYI and open for comments,
Thanks, and best regards, Horia
Horia
Re: Fibaro Motion Sensor (FGMS-001) Battery FYI for comments
Messagepar fullpower » 12 Nov 2022 14:11
Hello Horia,
Indeed it could be an evolution I think easy to set up and useful !
Personally I unchecked the non-communication alerts on certain devices on battery... and either the battery is completely empty or unchecking means that I no longer have a low battery alert...
:D
Programmation ARDUINO, NodeMCU, ESP8266 Eedomus + / Raspberry Pi 3 B + & Raspberry Pi 3 en programmation (Magic mirror)
Elegoo Mars - Artillery Sidewinder V2 - modélisation 3D sur Sketchup, Rhino 3d, Fusion 360, etc.
fullpower
Messagepar alfalfaleggings » 22 Jan 2024 07:59
Il semble que la fonction étant active trop longtemps entraînera une surcharge de certaines fonctions. Cela nécessite absolument de nettoyer et de réexécuter le programmegeometry dash lite. Merci d'avoir soulevé cette question pour enquête et bonne chambre.
alfalfaleggings
Retour vers Z-Wave devices
