Plug in Ampli Yamaha Series RX-V
Re: Plug in Ampli Yamaha Series RX-V
Messagepar merguez07 » 16 Nov 2018 21:38
Salut Frasab
essaye de faire ça :
Remplace le code php du plugin par celui ci
// Permet de recuperer les variables de l'ampli Yamaha.
$IP_Ampli = Getarg('IPAmpli');
$url="http://" .$IP_Ampli ."/YamahaRemoteControl/ctrl";
$get='<YAMAHA_AV cmd="GET"><Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone></YAMAHA_AV>';
$content = httpQuery($url,'POST',$post = $get, $oauth_token = NULL, $headers = NULL, $use_cookies = false, $ignore_errors = false);
$Power=xpath($content, '/YAMAHA_AV/Main_Zone/Basic_Status/Power_Control/Power') ;
$Volume=xpath($content,'(/YAMAHA_AV/Main_Zone/Basic_Status/Volume/Lvl/Val)*(-0.1)');
$Source=xpath($content,'/YAMAHA_AV/Main_Zone/Basic_Status/Input/Input_Sel');
$Output1 =xpath($content, '/YAMAHA_AV/Main_Zone/Basic_Status/Sound_Video/HDMI/Output/OUT_1');
$Output2 =xpath($content, '/YAMAHA_AV/Main_Zone/Basic_Status/Sound_Video/HDMI/Output/OUT_2');
if ($Output1=='On'){
    $Output=' OUT_1';
if ($Output2=='On'){
    $Output=' OUT_2';
$get='<YAMAHA_AV cmd="GET"><Spotify><Play_Info>GetParam</Play_Info></Spotify></YAMAHA_AV>';
$Artiste=xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Meta_Info/Artist') ;
$Album=xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Meta_Info/Album') ;
$Piste=xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Meta_Info/Track') ;
$Etat =xpath($content, '/YAMAHA_AV/Spotify/Play_Info/Playback_Info') ;
if (strpos ($Artiste,"NO_VALUE")===false) {
    saveVariable('ARTISTE', $Artiste);
    saveVariable('ALBUM', $Album);
    saveVariable('PISTE', $Piste);
} else{
    $Artiste=loadVariable('ARTISTE');
    $Album=loadVariable('ALBUM');
    $Piste=loadVariable('PISTE');
 // Generation du XML
sdk_header('text/xml');
    $xml = '<?xml version="1.0" encoding="UTF-8"?>';
    $xml .= '<Ampli_Yamaha>';
    $xml .= '<status>ok</status>';
    $xml .= '<power>' .  $Power .   '</power>';
    $xml .= '<volume>' . $Volume .  '</volume>';
    $xml .= '<source>' . $Source  . '</source>';
    $xml .= '<artiste>' .$Artiste . '</artiste>';
    $xml .= '<album>' .  $Album .   '</album>';
    $xml .= '<piste>' .  $Piste .   '</piste>';
    $xml .= '<etat>' .   $Etat .    '</etat>';
    $xml .= '<output>' .  $Output .    '</output>';
    $xml .= '</Ampli_Yamaha>';
echo $xml;
et dans l'actionneur Yamaha source tu modifies le xpath
/Ampli_Yamaha/source
par
concat(/Ampli_Yamaha/source,/Ampli_Yamaha/output)
Tiens moi au jus, si ça marche pas on fera d'autres manip
Messagepar frasab » 17 Nov 2018 11:52
Alors ça marche, mais :
- il est possible que les 2 sorties soient actives
- J'ai ajouté un actionneur HTTP pour pouvoir récupérer l'état (et les commander) pour baisser mon écran quand la bonne sortie est active
Merci beaucoup
frasab
Messagepar jeremy51 » 13 Mars 2019 17:52
Bonjour a tous,
je possède un ampli Yamaha HTR-4068 sur lequel j'ai une chromecast.
j'ai installé via le plug in du store eedomus mais a mon avis il faut que je fasse quelques modifs, par exemple je ne peux pas l'allumer mais par contre je peux l'éteindre.
Selon vous de quel côté dois je regarder ??
merci de votre aide
jeremy51
Retour vers Outils tiers
