ESPEasy bouton + temperature
Capteurs et actionneurs HTTP
Messagepar Benji206 » 23 Août 2019 11:48
Bonjour j'ai installé espeasy sur un mini arduino, avec un bouton et un capteur de temperature.
J'aimerai récupéré l'état du bouton et la température sur eedomus mais je me perd dans la formule XPath.
Voila se que je récupère:
{"System":{
"Build":20103,
"Git Build":"mega-20190817",
"System Libraries":"ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support",
"Plugins":48,
"Plugin description":" [Normal]",
"Local Time":"1970-00-00 00:00:00",
"Unit Number":1,
"Unit Name":"Bouton_garage",
"Uptime":168,
"Last Boot Cause":"Manual reboot",
"Reset Reason":"External System",
"Load":12.90,
"Load LC":4254,
"CPU Eco Mode":"false",
"Heap Max Free Block":18656,
"Heap Fragmentation":11,
"Free RAM":20920
"WiFi":{
"Hostname":"Bouton-garage-1",
"IP Config":"DHCP",
"IP Address":"192.168.1.56",
"IP Subnet":"255.255.255.0",
"Gateway":"192.168.1.254",
"STA MAC":"3C:71:BF:28:D7:32",
"DNS 1":"192.168.1.254",
"SSID":"Benjamin",
"BSSID":"F8:AB:05:08:1A:D0",
"Channel":1,
"Connected msec":10068963,
"Last Disconnect Reason":1,
"Last Disconnect Reason str":"(1) Unspecified",
"Number Reconnects":0,
"Force WiFi B/G":"false",
"Restart WiFi Lost Conn":"false",
"Force WiFi No Sleep":"false",
"Periodical send Gratuitous ARP":"false",
"Connection Failure Threshold":0,
"RSSI":-75
"Sensors":[
"TaskValues": [
{"ValueNumber":1,
"Name":"switch",
"NrDecimals":0,
"Value":1
"DataAcquisition": [
{"Controller":1,
"IDX":0,
"Enabled":"true"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":0,
"Type":"Switch input - Switch",
"TaskName":"bouton_lumieres",
"TaskDeviceNumber":1,
"TaskEnabled":"true",
"TaskNumber":1
"TaskValues": [
{"ValueNumber":1,
"Name":"Temperature",
"NrDecimals":2,
"Value":25.00
{"Controller":1,
"IDX":0,
"Enabled":"true"
{"Controller":2,
"IDX":0,
"Enabled":"false"
{"Controller":3,
"IDX":0,
"Enabled":"false"
"TaskInterval":60,
"Type":"Environment - DS18b20",
"TaskName":"Temp",
"TaskDeviceNumber":4,
"TaskNumber":2
"TTL":60000
Se que je veux récupérer l'état du Sensors switch et le sensors température.
Sur mon Xpath pour la température pas exemple je met : //Sensors[2]/TaskValues/Value
Résulat ERREUR: Valeur lue vide
Je n'arrive pas a trouver la bonne formule...
Merci d'avance de l'aide
Benji206
Re: ESPEasy bouton + temperature
Messagepar xeos » 23 Août 2019 22:51
Salut
Ce que tu recupere est du Json il faut deja que tu le transforme en XML.
Le xpath doit être je pense /Sensors/Sensors[2]/TaskValues/Sensors/Value/ et /Sensors/Sensors[1]/TaskNumber/
et si tu veux avoir une valeur 0-100 tu multiplie (/Sensors/Sensors[1]/TaskNumber/) * 100
Messagepar Benji206 » 24 Août 2019 10:25
Oui j'ai mis le json mais je le transforme bien en xml.
<root><System><Build>20103</Build>
<Git_Build>mega-20190817</Git_Build>
<System_Libraries>ESP82xx Core 2_5_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.1.2 PUYA support</System_Libraries>
<Plugins>48</Plugins>
<Plugin_description> [Normal]</Plugin_description>
<Local_Time>1970-00-00 00:00:00</Local_Time>
<Unit_Number>1</Unit_Number>
<Unit_Name>Bouton_garage</Unit_Name>
<Uptime>2</Uptime>
<Last_Boot_Cause>Manual reboot</Last_Boot_Cause>
<Reset_Reason>External System</Reset_Reason>
<Load>11.9</Load>
<Load_LC>4428</Load_LC>
<CPU_Eco_Mode>false</CPU_Eco_Mode>
<Heap_Max_Free_Block>19528</Heap_Max_Free_Block>
<Heap_Fragmentation>7</Heap_Fragmentation>
<Free_RAM>20960</Free_RAM>
</System>
<WiFi><Hostname>Bouton-garage-1</Hostname>
<IP_Config>DHCP</IP_Config>
<IP_Address>192.168.1.56</IP_Address>
<IP_Subnet>255.255.255.0</IP_Subnet>
<Gateway>192.168.1.254</Gateway>
<STA_MAC>3C:71:BF:28:D7:32</STA_MAC>
<DNS_1>192.168.1.254</DNS_1>
<SSID>Benjamin</SSID>
<BSSID>F8:AB:05:08:1A:D0</BSSID>
<Channel>1</Channel>
<Connected_msec>130517</Connected_msec>
<Last_Disconnect_Reason>1</Last_Disconnect_Reason>
<Last_Disconnect_Reason_str>(1) Unspecified</Last_Disconnect_Reason_str>
<Number_Reconnects>0</Number_Reconnects>
<Force_WiFi_B/G>false</Force_WiFi_B/G>
<Restart_WiFi_Lost_Conn>false</Restart_WiFi_Lost_Conn>
<Force_WiFi_No_Sleep>false</Force_WiFi_No_Sleep>
<Periodical_send_Gratuitous_ARP>false</Periodical_send_Gratuitous_ARP>
<Connection_Failure_Threshold>0</Connection_Failure_Threshold>
<RSSI>-73</RSSI>
</WiFi>
<Sensors><Sensors><TaskValues><Sensors><ValueNumber>1</ValueNumber>
<Name>switch</Name>
<NrDecimals>0</NrDecimals>
<Value>1</Value>
</Sensors>
</TaskValues>
<DataAcquisition><Sensors><Controller>1</Controller>
<IDX>0</IDX>
<Enabled>true</Enabled>
</Sensors>
<Sensors><Controller>2</Controller>
<IDX>0</IDX>
<Enabled>false</Enabled>
</Sensors>
<Sensors><Controller>3</Controller>
<IDX>0</IDX>
</Sensors>
</DataAcquisition>
<TaskInterval>0</TaskInterval>
<Type>Switch input - Switch</Type>
<TaskName>bouton_lumieres</TaskName>
<TaskDeviceNumber>1</TaskDeviceNumber>
<TaskEnabled>true</TaskEnabled>
<TaskNumber>1</TaskNumber>
</Sensors>
<Name>Temperature</Name>
<NrDecimals>2</NrDecimals>
<Value>25</Value>
</Sensors>
</TaskValues>
<IDX>0</IDX>
</Sensors>
<IDX>0</IDX>
</Sensors>
<IDX>0</IDX>
</Sensors>
</DataAcquisition>
<TaskInterval>60</TaskInterval>
<Type>Environment - DS18b20</Type>
<TaskName>Temp</TaskName>
<TaskDeviceNumber>4</TaskDeviceNumber>
<TaskNumber>2</TaskNumber>
</Sensors>
</Sensors>
<TTL>60000</TTL>
</root>
Avec /Sensors/Sensors[2]/TaskValues/Sensors/Value/ ca me met ERREUR: Expression xpath invalide
et avec /Sensors/Sensors[1]/TaskNumber/ ca me met ERREUR: Expression xpath invalide.
J'ai aussi essayé /Sensors/Sensors[2]/TaskValues/Sensors/Value et ca me met valeur vide.
J'ai vraiment du mal avec le xpath.
Merci de l'aide
Benji206
Messagepar xeos » 24 Août 2019 11:33
Alors essaye /root/Sensors/Sensors[2]/TaskValues/Sensors/Value
Messagepar Benji206 » 24 Août 2019 11:36
xeos a écrit:Alors essaye /root/Sensors/Sensors[2]/TaskValues/Sensors/Value
Toujours pareil valeur lue vide
Benji206
Messagepar Benji206 » 24 Août 2019 16:54
A force de bidouille j'ai réussi.
J'ai modiflé url de requête pour avoir un xml beaucoup plus petit et du coup un xpath plus simple.
Benji206
Messagepar Michteedo » 02 Fév 2021 21:14
Bonjour, vous avez trouvé; j'aurais aimé un exemple, merci....
Michteedo
Retour vers Requêtes HTTP
