Aide sur l'utilisation de xpath
Capteurs et actionneurs HTTP
Messagepar amans » 06 Avr 2017 12:03
Je cherche à lister toutes les occurences dans un xml
<root>
   <success>1</success>
   <result>
      <result>
         <mac>70:EE:50:06:47:54</mac>
         <last_rx>
            <bitrate>540</bitrate>
            <mcs>-1</mcs>
            <shortgi>0</shortgi>
            <vht_mcs>-1</vht_mcs>
            <width>20</width>
         </last_rx>
         <tx_bytes>14650000</tx_bytes>
         <last_tx>
            <mcs>-1</mcs>
            <width>20</width>
         </last_tx>
         <id>F4:CA:E5:F8:1A:28-70:EE:50:06:47:54</id>
         <bssid>F4:CA:E5:F8:1A:28</bssid>
         <flags>
            <vht>0</vht>
            <legacy>0</legacy>
            <authorized>1</authorized>
            <ht>0</ht>
         </flags>
         <tx_rate>12</tx_rate>
         <host>
            <l2ident>
               <id>70:EE:50:06:47:54</id>
               <type>mac_address</type>
            </l2ident>
            <active>1</active>
            <id>ether-70:ee:50:06:47:54</id>
            <last_time_reachable>1491474956</last_time_reachable>
            <persistent>1</persistent>
            <vendor_name>Netatmo</vendor_name>
            <host_type>networking_device</host_type>
            <l3connectivities>
               <result>
                  <addr>192.168.0.11</addr>
                  <active>1</active>
                  <reachable>1</reachable>
                  <last_activity>1491474956</last_activity>
                  <af>ipv4</af>
               </result>
            </l3connectivities>
            <primary_name_manual>1</primary_name_manual>
            <primary_name>Thermostat</primary_name>
         </host>
         <inactive>2</inactive>
         <conn_duration>953110</conn_duration>
         <hostname>Thermostat</hostname>
         <state>authenticated</state>
         <rx_bytes>14460000</rx_bytes>
         <rx_rate>12</rx_rate>
         <signal>-50</signal>
      </result>
      <result>
         <mac>20:D3:90:E7:87:20</mac>
         <last_rx>
            <bitrate>120</bitrate>
            <mcs>-1</mcs>
            <width>20</width>
         </last_rx>
         <tx_bytes>90390000</tx_bytes>
         <last_tx>
            <bitrate>722</bitrate>
            <mcs>7</mcs>
            <shortgi>1</shortgi>
            <width>20</width>
         </last_tx>
         <id>F4:CA:E5:F8:1A:28-20:D3:90:E7:87:20</id>
         <flags>
            <vht>0</vht>
            <legacy>0</legacy>
            <ht>1</ht>
         </flags>
         <tx_rate>0</tx_rate>
         <host>
            <l2ident>
               <id>20:D3:90:E7:87:20</id>
            </l2ident>
            <active>1</active>
            <id>ether-20:d3:90:e7:87:20</id>
            <last_time_reachable>1491474945</last_time_reachable>
            <names>
               <result>
                  <name>android-3f8c04fee27c50be</name>
                  <source>dhcp</source>
               </result>
               <result>
                  <name>Android-2</name>
                  <source>mdns</source>
               </result>
               <result>
                  <name>BubbleUPnP Media Server (SM-T520)</name>
                  <source>upnp</source>
               </result>
            </names>
            <vendor_name>Samsung Electronics Co.,Ltd</vendor_name>
            <host_type>tablet</host_type>
            <l3connectivities>
               <result>
                  <addr>192.168.0.14</addr>
                  <active>1</active>
                  <last_activity>1491474945</last_activity>
                  <af>ipv4</af>
               </result>
               <result>
                  <addr>192.168.0.9</addr>
                  <active>0</active>
                  <reachable>0</reachable>
                  <last_activity>1488139406</last_activity>
                  <af>ipv4</af>
                  <last_time_reachable>1488139406</last_time_reachable>
               </result>
               <result>
                  <addr>fe80::22d3:90ff:fee7:8720</addr>
                  <active>1</active>
                  <last_activity>1491474921</last_activity>
                  <af>ipv6</af>
                  <last_time_reachable>1491474916</last_time_reachable>
               </result>
            </l3connectivities>
            <primary_name>Tablette Samsung 10</primary_name>
         </host>
         <inactive>1</inactive>
         <conn_duration>102915</conn_duration>
         <hostname>Tablette Samsung 10</hostname>
         <rx_bytes>13510000</rx_bytes>
         <rx_rate>0</rx_rate>
         <signal>-58</signal>
      </result>
   </result>
</root>
Je veux que le xpath me retourne toutes les valeurs du champs <mac> trouvé.
Si je comprends bien la documentation eedomus je devrais tout simplement pouvoir faire //mac
Or cela me retourne uniquement la 1ère occurence.
Il y a donc quelque chose que je n'ai pas compris ou fais mal.
Une idée ?
amans
Re: Aide sur l'utilisation de xpath
Messagepar amans » 06 Avr 2017 12:06
L'idée première est de savoir si telle ou telle adresse mac sont présentes ou non dans le xml !
Si il y a une autre méthode...
Merci à vous
amans
Messagepar amans » 06 Avr 2017 12:20
Bon.... j'ai trouvé une solution en fait.
Je compte le nombre !
Si cela peut servir à quelqu'un :
count(//text()[normalize-space() = 'XX:XX:XX:XX:XX:XX'])
amans
Messagepar stef31 » 06 Avr 2017 13:55
Je n'avais pas compris la demande mais merci pour le partage. :)
Retour vers Requêtes HTTP
