Parrot Flower Power
Re: Parrot Flower Power
Messagepar anne-marie » 25 Sep 2014 11:27
la température, l'humidité et la luminosité
Le plus important pour moi étant l'humidité afin d'être alertée quand je dois arroser
Messagepar Jmorize » 25 Sep 2014 22:00
Un peu en brute désolé
Example Response:
{"plant":
{"created_at":"2012-06-11T15:07:34+02:00",
"display_position":2,
"fertilizer_id":null,
"fertilizer_type":null,
"id":88310,
"last_fertilizer_at":null,
"last_mist_at":"2012-07-04T09:17:18+02:00",
"last_water_at":"2012-06-19T10:37:53+02:00",
"location":"Office",
"name":"Wali",
"next_fertilizer_at":null,
"next_mist_at":null,
"next_water_at":null,
"note":"null",
"plant_type_family_id":448,
"plant_type_id":0,
"pot_color":-865717249,
"pot_shape":2,
"size":0,
"updated_at":"2012-07-09T20:00:32+02:00",
"user_id":24518,
"wcd_calibration_checked_at":null,
"wcd_calibration_ended_at":null,
"wcd_calibration_started_at":null,
"vdm_calibration_start_pending":false,
"vdm_calibration_check_pending":false,
"vdm_next_calibration_check_at":null,
"vdm_last_calibration_check_at":null,
"vdm_calibration_in_progress":false,
"vdm_water_pending":false,
"vdm_water_level":0.4767244698745552,
"vdm_precalibrated":false,
"vdm_water_cycle":null,
"vdm_water_instruction":"Use lukewarm tap water. Water well so that water drops out into the saucer and remove the excess water from the saucer after 15 min.",
"vdm_water_analyzing_until":null,
"vdm_mist_pending":true,
"vdm_mist_level":0.0,
"vdm_mist_instruction":"Mist only the leaves. Do not spray onto the flowers or fruits.",
"vdm_fertilizer_pending":true,
"vdm_fertilizer_level":0.0,
"vdm_fertilizer_instruction":"Use Flower fertilizer (e.g. N8-P12-K6). Follow the instructions on the bottle. Water as usual.",
"vdm_temperature_pending":false,
"vdm_temperature_advice":null,
"vdm_temperature_level":0.9613715556530374,
"vdm_temperature_instruction":null,
"vdm_temperature_hint":"Wali is too warm.",
"vdm_temperature_analyzing_until":null,
"vdm_light_pending":false,
"vdm_light_advice":null,
"vdm_light_level":0.20501990425301445,
"vdm_light_instruction":null,
"vdm_light_hint":"Wali has too much shade.",
"vdm_light_analyzing_until":null,
"pot_color_hex":"cc6633",
"has_smart_device_associated":true,
"plant_photos":[]}}
Jmorize
Messagepar Madoma73 » 26 Sep 2014 02:51
Euh ?
Ça veut dire que tu as déjà fait le script ?
Messagepar Jmorize » 26 Sep 2014 07:33
Madoma73 a écrit:Euh ?
Nan pas du tout, c est le retour d'info fourni par l api koubachi. C était pour faire suivre au post précédent ou tu demandait quelles infos nous pouvions récupérer
Jmorize
Messagepar Tinto » 26 Sep 2014 08:09
L'API a l'air déjà bien avancée :)
Tinto
Messagepar Madoma73 » 27 Sep 2014 10:43
ca y est, les difficultés sont passées...
il reste la mise en forme
Messagepar technoseb27 » 29 Sep 2014 17:32
Je suis en train de voir que le tuto pour le parrot flower va être mis sur le site de domo-blog. Encore un grand merci à vous tous et surtout Madoma73 pour l'avoir fait. ;)
Voici mon blog :
technoseb27
Messagepar Madoma73 » 29 Sep 2014 18:59
oh, le gros boulet !!
j'ai cliqué sur "mettre en ligne" au lieu de "sauvegarder le brouillon"....
je me suis trahi.....oui, le script est presque fini et j'ai commencé à écrire le tuto.
cet article là, n'est pas fini, mais je vous en ai prévu un autre pour demain.
Messagepar technoseb27 » 29 Sep 2014 20:09
Ah désolé d avoir balancé lol. Je le redis du superbe travail que tu nous fait la. Surtout moi avec mes deux flower. L annee prochaine je vais pouvoir utiliser ceci pour le potager mais le premier va me servir pour ma plante intérieur
Voici mon blog :
technoseb27
Messagepar technoseb27 » 16 Oct 2014 23:43
Salut ça en est où la mise en ligne du tuto sur domo blog ?
Voici mon blog :
technoseb27
Messagepar Madoma73 » 06 Nov 2014 17:19
Après beaucoup beaucoup de retard.... :? :?
le script est en test !
Article et pack d'icônes pour la fin de la semaine... - croix de bois, croix de fer.....
Messagepar Madoma73 » 09 Nov 2014 22:32
Chose promise..
Article en relecture, suivez domo-blog.fr dans les prochains jours
Messagepar noodlesft » 14 Nov 2014 09:31
Merci pour le tuto et le pack d'icones...
Je fais le test ce soir :D :D
noodlesft
Messagepar Madoma73 » 14 Nov 2014 10:13
tes retours m'intéressent ! n'hésite pas
Messagepar aurel » 14 Nov 2014 13:25
Merci pour ton article Pierre, je ne connais pas bien le fonctionnement du FP mais a ce qu'il me semble il communique avec le serveur en bt via un smartphone, c'est bien ca?
cela implique un androphone dédié pour faire la passerelle pour alimenter les datas en continue?
aurel
Messagepar Madoma73 » 14 Nov 2014 13:31
oui, c'est un des gros inconvénients des flower power, il utilise le bluetooth d'un smartphone.
si tu veux une alimentation en continue des données, oui, il faut une passerelle, après pour une plante, ce n'est pas forcément nécessaire d'avoir une très grande granularité.
A mon avis, savoir une fois par jour si ta plante a tout ce qu'il te faut (par exemple le soir après que tu sois rentré chez toi) est suffisant.
Après, je peux envisager de modifier le script pour qu'il soit plus intelligent et récupère l'historique depuis la dernière valeur qu'il connait, c'est faisable, je ne suis pas sûr que ça en vaille la peine.
Messagepar aurel » 14 Nov 2014 13:45
non non, ton script est parfait c'est la conception du produit qui l'est moins... ce qui est embêtant c'est que pour avoir un état à jours dans l'eedomus, il faut ouvrir l'appli... du coup tu recupere visuellement son état dans l'apli avant que l'eedomus soit au fait, c'est la ou il faut une passerelle pour que ça prenne tout son sens, mais à la vitesse ou on change les smartphones c'est pas le plus compliqué à trouver :D
aurel
Messagepar anne-marie » 14 Nov 2014 21:59
Oui effectivement c'est le gros défaut du flowerpower tous comme beaucoup d'objets connectés en bluetooth.
D'autant qu'il faut être assez près de la plante pour récupérer les données.
Mais comme dit Pierre, une fois par jour suffit largement pour connaitre les besoins d'une plante.
Peut-être serait-il utile de savoir l'heure des dernières données fournies par la plante et non par l'API depuis l'Eedomus.
En tous cas, un grand merci à toi d'avoir donné de ton temps pour répondre à cette demande :)
Messagepar noodlesft » 16 Nov 2014 10:18
Voici mon retour sur la mise en pratique du tuto.
Concernant la marche à suivre tout est OK (simple et bien expliqué :) );
Petit point d'attention, chez moi pour les statuts, tout était à 'statut_ok' lors de l'ajout des capteurs HTTP, alors que les valeurs n'étaient pas toutes 'statut_ok' sur la réponse du script :shock:
J'ai du attendre une nouvelle récupération des données pour avoir la bonne valeur.
Autre chose étrange, pour l'humidité, j'ai le résultat suivant dans le script :
<soil_moisture>
<status/>
<instruction/>
<current_value>22.4</current_value>
<current_value_percentage>-28.1</current_value_percentage>
<min_threshold>17.5</min_threshold>
<max_threshold/>
</soil_moisture>
Du coup j'ai une erreur de remontée du statut (valeur lue vide).
Et dernier petit point, le lien vers le pack d'icônes semble KO sur le site 'No file attached yet.'
Après effectivement, comme dit plus haut, l'intérêt est limité à cause de la connexion bluetooth à un smartphone obligatoire...
Sais-tu s'il est possible via l'API de connaitre la dernière date de synchro des données ?
Car pour moi le principal problème c'est que je ne pense jamais à faire la synchro. Faire remonter cette date me permettrai de créer des règles de rappel.
Encore merci pour ton script et ton tuto !!!
Martial
noodlesft
Messagepar aurel » 16 Nov 2014 14:59
salut noodlesft, correction faite pour le pack d'icônes, le lien est bon a présent, n' hésite pas à faire ce type de remonté directement dans les commentaires du blog pour plus de réactivité ;)
aurel
