Premier paramétrage shelly qubino
Messagepar Frefcre » 03 Jan 2024 20:17
Bonjour à tous, nouveau propriétaire d'une eedomus plus et novice, je souhaitais domotiser ma porte de garage avec un module shelly qubino wave 1 et impossible de trouver comment paramétrer le contact impulsion ! Help
Frefcre
Re: Premier paramétrage shelly qubino
Messagepar lougarou60 » 05 Jan 2024 09:59
La configuration du module Shelly en lui-même c’est dans le cloud Shelly via PC ou smartphone
Rubrique « Paramètres » du module
lougarou60
Messagepar lilycollin89 » 26 Jan 2024 04:44
Congratulations,
To configure the pulse contact of the Shelly Qubino Wave 1 module on the Eedomus Plus, you must follow these steps:
Connect the Shelly Qubino Wave 1 module to your Eedomus Plus.
Open the eedomus plus app.
Go to the “Devices” page.
Select the Shelly Qubino Wave 1 module.
Click the “Settings” tab.
In the "Device type" section, select "Pulse contact".
In the "Sensitivity" section, set the module's sensitivity.
In the "Pulse duration" section, set the pulse duration.
Click to save"slope.
lilycollin89
Messagepar quickchortle » 26 Jan 2024 10:49
Follow these procedures in order to configure the pulse contact of the Shelly Qubino Wave 1 module on the Eedomus Plus:
The Shelly Qubino Wave 1 module must be connected to the Eedomus Plus.
Launch the Eedomus Plus application.
Navigate to the "Devices" section.
Choose the Wave 1 Shelly Qubino module burrito craft
Navigate to the "Settings" tab.
Select "Pulse contact" from the "Device type" menu.
Configure the sensitivity of the module in the "Sensitivity" section.
Configure the pulse duration in the "Pulse duration" section.
Select "Save"
quickchortle
Messagepar criminalemail » 21 Fév 2024 03:03
Through the "Parameters" part of the module on your PC or smartphone, you can access the Shelly cloud where the configuration of the module is located.
criminalemail
Messagepar Mirandajoye » 22 Fév 2024 03:49
Assurez-vous que le module Shelly Qubino Wave 1 est correctement installé sur votre porte de garage selon les instructions du fabricant. Assurez-vous également Palworld Breeding Calculator que le capteur de contact ou de positionnement est correctement connecté au module.
Mirandajoye
Messagepar deniolps » 08 Avr 2024 09:39
Mirandajoye a écrit:Assurez-vous que le module Shelly Qubino Wave 1 est correctement installé sur votre porte de garage selon les instructions du fabricant. Assurez-vous égalementsnow rider 3d que le capteur de contact ou de positionnement est correctement connecté au module.
Installé correctement. L'erreur ne vient pas de l'installation.
deniolps
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 52 invité(s)
